Windscreen
Old Apr 12, 2008 | 09:48 PM
CBR_600_Rider83's Avatar
Default RE: Windscreen
Ok lets try this again
Old Apr 12, 2008 | 09:53 PM
Karl's Avatar
You need to make the IMG into img or even [IMG] thats what i do
Old Apr 12, 2008 | 10:01 PM
tangerinedream's Avatar
Looks good!
ok try this
Old Apr 12, 2008 | 10:03 PM
thanks tan I used the Krylon fusion it worked really well.
Old Apr 12, 2008 | 10:06 PM
So I assume you took took normal prep painting procedures? Did you put the paint on the inside or outside?
Old Apr 12, 2008 | 10:08 PM
inside and all you need to do is clean it really good with an anmonia based cleaner. then paint away.
Old Apr 12, 2008 | 10:44 PM
Karl's Avatar
Did you not need to key the surface first with some sort of fine sand paper or wire wool first so the paint has something to stick to?
when i sprayed the screen on my old cbr600 F-L i keyed it, cleaned it, primed it and sprayed both sides to save from getting that 'orange peel' effect i think it looked pretty good
Old Apr 13, 2008 | 06:36 PM
mmgsport's Avatar
you're almost ALWAYS gonna get the orange peel when painting plastic - the material has too much flex not to - and not to mention the pores in it - its just not the same as metal -
thats why whenever you take a car to the bodyshop the bumper never quite matches the quarter panel again - just different surfaces
Old Apr 13, 2008 | 08:01 PM
03yellow6000RR's Avatar
ORIGINAL: CBR_600_Rider83
