Turn signals
Old May 28, 2007 | 02:53 AM
red_devil's Avatar
Default Turn signals
I am changing my rear trun signals took every thing off wierd the new signals, but when i put them on they dont blink they stay on. Any one knows what the problem is??????
Old May 28, 2007 | 02:54 AM
knightslugger's Avatar
Default RE: Turn signals
LED?
Old May 28, 2007 | 05:30 AM
Blue Fox's Avatar
Retired Moderator
You need to wire in a resistor somewhere (either on the rear turn signal or the front turn signal) for each side. That'll give you a fast blink. You will need to wire in 4 resistors (1 for each signal) to get the stock blink back.
Old May 29, 2007 | 04:17 AM
CBRFREEK's Avatar
You need to check your wiring or u blew a fuse.Id bet its one of each.
Old May 30, 2007 | 03:41 AM
Ponger's Avatar
Do you have the front marker lights sorted out? When I was doing mine, I had the same problem. The issue wasn't the rear markers but the front.
The front (and rear)negative is the factory green wire and the frontpositive is going to be the orange or blue wire.
The (front) running lights are the orange/white and blue/white.
I used some "Bullet" connector to micro-connector abaptors by Lockhart -Phillips. I think they were all of $5.00.
If you have access to a really fine flat head screwdriver like the type to fix glasses with, you may be able to reach into the connector on the turnsignal side and unhook the micro-connectors (...if you are carefull with a small wire cutter you can disectone of the Lock-Hart Phlillips housings, the connectorswill make perfect sense than...).I used a flat dental tool.
Ithen located the correct connectors to the harness by simplyconnecting the micro-connectors together (get some spare fuses ready) and when the maker lights worked in conjuction I snapped them into the stock connectors housing.
Snap the factory harness connectors together and clean up your mess, and away you go. I hope this made sense?
Old May 31, 2007 | 11:56 AM
red_devil's Avatar
Thanks guys all i needed was a resistor.
Lowridese
May 1, 2010 01:12 AM
MrBlaze
Aug 17, 2009 02:07 AM
playb0i
Jan 2, 2009 04:55 PM
Terry954rr
Jul 25, 2008 08:32 PM
Neutron
Sep 28, 2006 02:47 PM
