Transmission ?
Old Jul 1, 2008 | 07:41 AM
bcrosby51's Avatar
Default Transmission ?
How bad is it to not use your clutch when shifting gears. I don't think it would be too bad when I do low speed upshifts, but what about when I cruising at 70 and give it a little gas and pop it down a couple speeds without using the clutch. I am just asking to have tranny problems or are they built to take that?
Old Jul 1, 2008 | 11:52 AM
tmyers7791's Avatar
Default RE: Transmission ?
Ive been doing clutchless shifts up and down for years...my gears still have all thier teeth and i have had no problems. Its all a matter of timing as long as its a smooth transition between gears with no grinding...you should be fine.
Old Jul 1, 2008 | 02:22 PM
shoortbuss's Avatar
I also shift quite a bit without the clutch...shouldn't be a big deal as long as you are doing it right. I wouldn't worry about it.
Old Jul 1, 2008 | 02:42 PM
heybuddy1901's Avatar
no syncros.
it wont pop until its all lined up.
i see more damage to your engine by "popping it down a few gears"
i clutchless upshift all the time, not a big fan of the downshifts.
i like to rev match on the down shifts.
Old Jul 1, 2008 | 02:56 PM
bcrosby51's Avatar
Yeah, I wouldn't call the downshifts smooth. I just push down on the shifter a bit, give it some gas and it pops down.
Old Jul 2, 2008 | 01:40 AM
skitzofrenzy's Avatar
shouldnt hurt too much. i always have done it on multiple bikes. no worries
Old Jul 4, 2008 | 08:33 AM
fastBYfritz's Avatar
I have an air shifter with an ignition kill I use on my 6peice for dragracing. Clutchless up shifts are all good. But I wouldnt down shift clutchless. You will bend shift forks and its hard on the transmission.
JankCibberf2
F2 Tech
Feb 28, 2012 10:11 AM
Nevets
Sep 3, 2010 10:31 PM
dusterdude
Jan 28, 2009 09:07 PM
Stephens
Apr 15, 2007 03:35 AM
