tires
Old Nov 24, 2007 | 05:01 PM
iroc's Avatar
Default tires
is there any advantage in usin a 190/50 17 as to the original 180/55 17? i wont ever run on a track, nor will i ever do any major cornering, 90% of the riding will b hiway ...and will the difference in tire affect the speedo any? thanks for ur responses
Old Nov 24, 2007 | 06:41 PM
knightslugger's Avatar
Default RE: tires
no.
Old Nov 24, 2007 | 08:24 PM
iroc's Avatar
Default RE: tires
um ok..? no to all of them?
Old Nov 24, 2007 | 08:31 PM
Default RE: tires
doing commuter miles will not effect your riding regardless of your tire choice. the speedo will be different but only very slightly and not to the point i would worry over it.
Old Nov 24, 2007 | 08:40 PM
Demon RR's Avatar
Default RE: tires
correct me if im wrong. i dont think you can run a 190/50 on your 600. the rear wheels are different size. so if i was told a rear wheel from a 1000rr will not fit on a 600rr, then i doubt the 600 will fit the 190/50 stock 1000rr tire.
i might be wrong tho.
Old Nov 24, 2007 | 08:48 PM
Default RE: tires
the wheel is a different size (6 inch vs. the 600rr's 5.5 inch) but you can shoe horn a 190/50 on there... it's just not very advisable. you deform the tire doing so. a 190/55 is a better choice if you wanted to change the sizes.
Old Nov 24, 2007 | 09:00 PM
Demon RR's Avatar
Default RE: tires
ORIGINAL: knightslugger
yup, i already run a 190/55. LOVE IT!!
Old Nov 24, 2007 | 09:01 PM
iroc's Avatar
Default RE: tires
ah ok yes i was wrong i was thinking the 190/55, but it makes no difference either way ill play it safe and stay w/ the 180/55......thanks
Old Nov 24, 2007 | 09:17 PM
sixhundredrr's Avatar
Default RE: tires
ORIGINAL: iroc
I went from a 190 (previous owner) to a 180 and it is a world different. Honda designed the bike to run with a certain tire size and changing that effects a variety of aspects from handling to tire wear. I like my 180 and will not go back. The 190, when worn, had a more defined flat spot in the center which made turn in much more difficult and leaning much more difficult.
Getz2003
May 31, 2009 01:35 AM
Exitwounds
Oct 28, 2008 07:18 PM
Greyfox5
Jul 4, 2007 01:56 PM
barryem
May 14, 2007 02:12 AM
barryem
Apr 11, 2007 10:42 PM
