thumb brake?
Old Jul 29, 2008 | 06:04 PM
Gville George's Avatar
Default thumb brake?
posted this in the general tech but no response, plus the site wouldn't let me make a long post.
has anyone here used a thumb brake instead of the usual rear foot brake. I am thinking about getting one because i don't really lik e the foot brake, i feel lik e i don't enough control with it and i lock it up to often. because if that i usually just u se the front brakes.
Old Jul 29, 2008 | 06:06 PM
Default RE: thumb brake?
i found some on line today and it made me want o ne.
http://www.hardracing.com/GP%20Tech/Thumbrake.htm
do you guys think it would be strong enough to control a wheelie? I think i would rath er ha ve th at the n a reg ular lev er st yle ha nd br ake bec ause yo u ca n us e it wh ile usi ng t he clu tch (i w ould th ink)
Old Jul 29, 2008 | 08:32 PM
be vertical's Avatar
I think it would work great on a super light race bike with very low sprung weight and really sensitive multi-piston calipers. Im skeptical about its practicality for street use.... The key here is leverage. If you think about it, you have enough force in your grip to use the front brake, however you are diluting the amount of input force needed because of the larger rotors, and the fact that their is two setups, causing each of them to work less hard... which = less input force. You also have to consider that you are not fighting the engine with the front brake, and you are with the rear... with half the hardware.
You might be able to rig it up in combination with the foot control as well, but that might involve setting up a separate caliper on the same rotor, which seems like a bit much for the given application....
Old Jul 30, 2008 | 03:50 AM
skitzofrenzy's Avatar
race bike? sure, street? why? if you want something for stunting just get a stunt clutch kit. you know, a half cut brake handle and a ful length clutch handle. they are made for the stuff you want to do
zellster
Aug 19, 2019 06:44 PM
6doubleohf3
Oct 25, 2009 09:01 AM
phillycbr
Sep 2, 2009 10:35 PM
Gville George
Jul 29, 2008 07:12 PM
Hayden06F4i
Jun 17, 2008 09:50 AM
