throttle positioning sensor
Old Aug 16, 2006 | 07:59 PM
dudek12's Avatar
Default throttle positioning sensor
Could someone please explain how to reset my throttle positioning sensor thanks
Old Aug 19, 2006 | 01:13 PM
jwp6114's Avatar
Default RE: throttle positioning sensor
do you have a power commander?
if so, hook up to your lap top and turn your key on. start the power commander program and at the top in one of the menues there is atab with set throttle posistion in it. click it. when the windo opens you will see a bar with numbers to the left and right of it, this is what the power commander is reading, the number boxes below it you can input the numbers from above when the throttle is at full closed and full open. i reccommend doing this with the engine off. let me know if this helps
Old Aug 25, 2006 | 11:54 PM
dudek12's Avatar
i got to that point but iam not too sure what #rs to put in?
Old Aug 26, 2006 | 12:06 AM
dudek12's Avatar
i went to the set throtal postion thing on the tool bar and reset it and now the throtal numbers is goin crazy on the side and allso on the power comander the bars are goin crazy as well
Old Aug 27, 2006 | 11:03 AM
jwp6114's Avatar
are you doing this with the engine off?
you shoud turn the key on and run the program, open the throttle position re calibrator tool, and input the number on the left side under the closed side, then turn the throtle wide open and input that number on the open side.
Old Aug 27, 2006 | 09:01 PM
dudek12's Avatar
i got it to work after awhile of playing around havent got a real good chance to ride because of the rain
Old Aug 28, 2006 | 11:07 PM
jwp6114's Avatar
you should feel a little difference. not sure i did it all at once, uploaded map, reset throttle posistion sensor, and did a slip on exhaust.
SixHundo
Jul 31, 2019 10:44 PM
crlydave
Dec 10, 2011 04:37 PM
kharvey
Aug 24, 2010 05:23 PM
kharvey
Aug 20, 2010 10:10 AM
f3BikeR
Dec 3, 2008 08:09 PM
