throttle
Yeah but there is supposed to be some free play there. I think 3/8 of an inch max. On the throttle theisan adjusternut an 8mm and a lock nut 10 mm. Loosen the lock nut and use the adjuster to give some tension. Give it a quarter turn and check the play. Keep doing it till you got it with in spec. It should be in your owners manuel. Don't forget to retighten the lock nut.
Neu16
May 25, 2013 01:18 AM
zellster
Sep 29, 2010 02:42 AM
