temp sensor
anyone ever hear of the temp sensor going bad mine spikes to 240 when stoped and just jumps all over the band with to like 155 all the way to 240 within seconds but when crusing just stays at normal temps 170-190
sounds like the wire going to the sender might have a short in it
or a melted spot that may be grounding out to the body
that is how that sensor works the hotter it gets the less the resistance. if the wire is grounding out then it will give erraditc readings
