Tail Light out of commission
Old Sep 28, 2009 | 07:51 PM
esummers's Avatar
Default Tail Light out of commission
Got pulled over last night because my tail light isn't working. This happened to me about 4 months ago, but I just shut the bike off and turned it back on and all was good.
Seeing as this happened before, I'm guessing it's not a fuse - although I'll check it out tonight. If it's wiring, I'm screwed as I know zero about wiring. Any help would be appreciated.
It's a 2007 cbr600rr with a fender eliminatior and the tail light right under the Yoshi Pipe.
Thanks guys
Old Sep 29, 2009 | 09:36 AM
swift25's Avatar
Sounds like you have a short in wire connection from your taillight to the bike wiring harness. Not hard to figure out, first off you are gonna need a test lite. That allows you to see were power is coming from. Take off your tailsection & check out how everything is wired to the taillamp. From your taillight, there should be a positive wire(normaly red) & a negative wire(normaly black). Follow those wires to see how they are connected to the bike's positive & negative wire. Thats were your problem most likely is if your taillight keeps shutting off.
mikemoore
Sep 8, 2010 01:07 PM
tutman6
Apr 1, 2006 02:47 PM
