squelling brakes
Old Mar 29, 2008 | 06:33 PM
sk8rat's Avatar
Default squelling brakes
I let some guy hold my bike to take it for a spin around the corner and back and he totally abused my bike doing stupid stuff like wheelies and drifting anywho when i use my front brake at low speeds is there anything i can do to fix this
Old Mar 29, 2008 | 07:19 PM
sixhundredrr's Avatar
Default RE: squelling brakes
Problem 1: Letting someone ride your whip.
Solution 1: Don't do it.
Problem 2: Squealing
Solution 2: Check how worn down the pads are visually. You can tell if they are getting close to the backing. If you see a little piece of metal touching your rotor (the squeal/time to replace indicator), you need pads.
If this doesn't help, come back with a more descriptive version of exactly when the problem happens and when it doesn't. Example: it only does it when I've been riding under 2 minutes and speeds under such and such.
Old Mar 29, 2008 | 09:44 PM
be vertical's Avatar
Agree'd...
General Rule of Thumb: Friends that ride gixxers should not touch honda's.
Old Mar 29, 2008 | 10:58 PM
dwschultzy's Avatar
Did you slap the guy around? He was playin you like a punk. Nobody does that to another man, nobody except for punks. As soon as the kickstand would have touched the ground I would have been on him like a cheap suit.
What are you doing letting some d*ckhead ride your bike? Hopefully you learned your lesson.
*** far as the brakes go, follow sixhundredrr's advice. Take a close look at the pads, if they are not worn down they could be glazed over.
Old Mar 29, 2008 | 11:27 PM
CBR_600_Rider83's Avatar
I am in total agreeance with dws I would have beat that guy like he has never been beatin' before. Dose the term curbie mean anything to you? But I do have to say you most likely need new pads. Hope that is all you need.
Old Mar 31, 2008 | 02:13 AM
REDrum's Avatar
If your pads are good, then I would say that this guy put a "glaze" on your pads. You can do 2 things if this is the case. 1; remove the pad and lightly sand it. Just scuff the surface. 2; you can put some silicone gasket sealant between your caliper and your pad. This will absorb the vibrations causing the squealing.
Nytmr
Dec 21, 2013 09:16 PM
juiceweezle
Jul 4, 2009 04:14 PM
wrx84
Apr 24, 2007 04:19 PM
bignibb
Apr 5, 2007 07:44 PM
JZHALES
Mar 23, 2007 01:47 PM
