SLIP OUT OF 6TH!!!!!!
Old 07-14-2006, 10:15 PM
jwp6114's Avatar
Default SLIP OUT OF 6TH!!!!!!
anyone ever get on it and get to 5th fine... shift into 6th and the tranny slip back down to 5th?????
any idea what the problem might be?
oil chang 1300 miles ago???????????[sm=wtf.gif]
Old 07-15-2006, 08:54 PM
Default RE: SLIP OUT OF 6TH!!!!!!
I've had it happen once i went from first to second and it dropped to nuetral after about a second but never before then or since then.
Old 07-15-2006, 09:21 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Sometimes it's due to a soft shift -- not saying that you gotta slam it into every gear but we all get lazy from time to time. If it starts happening on a regular basis then it's almost always either a bent or worn shift fork.
Old 07-15-2006, 10:45 PM
jwp6114's Avatar
it doesn't happen all the time mostly when i blip the throttle closed and shift without the cluch, <---- is this a realy bad thing to do?...
what can cause a bent shift fork? I would imagine you have to break the crank case apart to fix it?
Old 07-15-2006, 10:57 PM
In most cases you're correct about splitting the cases and I'm not sure about the 600RR but the 1000RR has a "cartridge" style tranny that you can completely pull with the engine still in the frame. Maybe the 600RR is the same. And upshifting without the clutch isn't necessarily a bad thing. But if you don't time it right and have to slam it into the next gear then you can bend a shift fork. A worn fork is just a result of time and miles.
Old 07-15-2006, 11:45 PM
jwp6114's Avatar
thanks chain, i got 7300 miles on my ride and 1300 sence last oit change... maby i will try shifting normaly for a while and see if it happens again.. let me know if you find out if the 600rr has a cartrage tranny like the 1krr.
Mehmed
09-10-2012 08:11 PM
Gsxr_eater
09-28-2008 01:00 AM
Diablo Runner
12-09-2007 05:18 PM
Quick Reply: SLIP OUT OF 6TH!!!!!!
