SLIP OUT OF 6TH!!!!!!
RE: SLIP OUT OF 6TH!!!!!!
In most cases you're correct about splitting the cases and I'm not sure about the 600RR but the 1000RR has a "cartridge" style tranny that you can completely pull with the engine still in the frame. Maybe the 600RR is the same. And upshifting without the clutch isn't necessarily a bad thing. But if you don't time it right and have to slam it into the next gear then you can bend a shift fork. A worn fork is just a result of time and miles.
