power commander
If it's set up wrong then it will be nothing. A Power Commander is a tuning device used to fine tune the fueling and is best used with an exhaust and/or upgraded air filter. You would be able to get aminimal increases on a standard bike but the time and cost of having it properly set up on a dyno wouldn't make the increse worth while. Any gain would be mainly smoothing out the power and fueling.
www.powercommander.com/powercommander_iii_usb/powercommander_information.aspx
yep
the PC is not a hp increasing device. it makes the air fuel curve correct which keeps the bike from running to rich or lean.
this is turn gives the added advantage of increasing hp
by leaning out rpm/throttle position places where it is too rich and the opposite where it is too lean
ORIGINAL: 05chromedRR
is it really worth buying one if you dont race? i wanted to get one but i dont race.
Adding just a Power Commander to your bike will improve the rideability (very important, more important than horsepower)of the bike, without a doubt. Horsepower gains will be minimal unless the bike is way off on it's fueling, which is very likely considering the new emissions standards. The newer your bike is the more improvement I would excpect from adding a Power Commander due to the strict emissions standards getting stricter over time.
maxwell139
05-16-2006 01:30 AM
