OIL Leaks
Old Apr 12, 2008 | 01:08 PM
mingstah's Avatar
Default OIL Leaks
I recently changed my oil, and I think I might have added a little more than 3 Qtz of oil. Would this cause a leak after a ride? Is it possible to check if my oil is too full?
Old Apr 12, 2008 | 01:16 PM
CBR_600_Rider83's Avatar
Default RE: OIL Leaks
ya that would be one cause. yes there is a looking glass on the very bottom of the motor on the left hand side of the motorcycle if it is over the full make then you put to much in. Also check the oil filter if it is on steright or tight enough. Good luck and hope i was some help.
Old Apr 12, 2008 | 01:19 PM
jutsin's Avatar
like cbr rider said make sure to check the filter and the drain bolt are tight... You don't want a trail of oil left right where your rear tire is going
Old Apr 12, 2008 | 01:27 PM
mingstah's Avatar
oo thanks i'll go check on it right away!
Old Apr 12, 2008 | 05:06 PM
wellarmedCr@cker's Avatar
Oil filter being too tight can also cause a problem.
Old Apr 12, 2008 | 08:03 PM
xxenycejattxx's Avatar
yeah just check the oil levels on the side in the mirror.!!
you bike give you some extra smoke if you put too much in it!!
Old Jan 25, 2009 | 01:10 PM
kmitch_78's Avatar
I have a question about my 2005 1000CBR, I have a slight oil leak I see the drip that froms on the wire harness on the right side of the bike by the oil glass. If you need pics I can add them. I was wondering if anyone had this problem and whatt possibly could it be.
boredandstroked
Apr 24, 2011 01:45 PM
pinefresh
Mar 7, 2009 03:08 AM
1stbikeowner
Jun 17, 2008 01:54 PM
wishin4600rr
May 14, 2008 06:50 AM
znelson72
Sep 18, 2007 10:27 PM
