NEW To the Ryders community!
Old Jun 4, 2007 | 05:07 AM
sRt85's Avatar
Default NEW To the Ryders community!
My name is Rt and I just bought an 07 cbr600 rr and I was wondering if theres a HOW to on here to eliminate the "UFO"looking liscense plate holder? It just looks so ugly without I ve tried to take it off once but it seems I have to take quite a bit? LMK ASAP please! thanks for reading!
Old Jun 4, 2007 | 01:26 PM
bjtoth1's Avatar
Default RE: NEW To the Ryders community!
Rt whats up man. i just took mine off and put a fender eliminator on. This is what you have to do. take of driver seat, to do this pull up the back corners of the seat and there is 2 alan bolts to take off. One on each side. then take off back seat and remove the 4 bolts for the back faring.Now take off the back faring the easiest way that i found is to grab each side in the front and then pull outward and slide it back. It comes off real easily actually. But make sure you remember which bolts go where (i believe the smaller ones go in the front.then there will be 2 more bolts on each side for the ugly brake assembly on each side of the exhaust and then your done. It will still be connected by the wiring though. If you wanna take it off completely this is what you do. Under the drivers seat there is 3 clips are for the brake light and turn signals. They just snap right on and off disconnect and then pull the wiring through. This will leave no brake light and no rear turn signals though your call. Go to this link and see if you like this eliminator kit. I bought one and i looks sweet and pretty easy to install. Hope this helped
http://cgi.ebay.com/ebaymotors/HONDA...25394223QQrdZ1
Old Jun 4, 2007 | 04:06 PM
dpeach06's Avatar
Hello and welcome! Just look around web sites and see which fender eliminator you like. I think im going to get the Rizoma, personally it looks the best. Try these sites, should get you on a good start.
www.bikelitez.com
http://www.rizoma.it/Prodotti/Prodot...D_categoria=23
Old Jun 4, 2007 | 04:18 PM
bjtoth1's Avatar
I thought the while point of the fe was to make it look better the rizoma in my opinion isnt much of an improvement from the stock one
Old Jun 4, 2007 | 04:33 PM
sRt85's Avatar
VERY NICE MAN! I will go to work on it right now! thanks for info!
Old Jun 4, 2007 | 07:24 PM
eee4666's Avatar
Buy the 03-06 integrated tail light. Only thing I would consider, personally i dont like anything else out there. (I just ordered it last friday)
Old Jun 4, 2007 | 07:40 PM
bjtoth1's Avatar
to bad that we cant buy the intergrated taillight kit considering out brake light isnt under the seat
Old Jun 4, 2007 | 08:41 PM
sRt85's Avatar
Hey BJ does your eliminator kit have both turn signals and brake light built in?
Old Jun 4, 2007 | 08:53 PM
bjtoth1's Avatar
ya it has the brake light and turn signals which are all leds also so they are bright as hell also and will almost never burn out. did you look at the link in the post i put up earlier you can see it there.
Old Jun 6, 2007 | 03:47 AM
eee4666's Avatar
ORIGINAL: bjtoth1
Sure you can, needs to be modded a little bit. Both the tail as well as the light. It's been done numerous times.
Check this out http://www.600rr.net/vb/showthread.php?t=73857
f4i-4life
May 31, 2012 07:48 PM
ccsracer216
Sep 8, 2008 10:57 AM
ddvs
Sep 1, 2006 02:55 PM
stephygee
West
Aug 29, 2006 04:50 PM
stephygee
Jul 19, 2006 02:20 PM
