Need map
Old Mar 2, 2009 | 02:57 PM
sixfive407's Avatar
Default Need map
Have no money to custom dyno my power commander. Powwercommander.com doesnt list for a yoshi slip on. RS-5 to be exact. Didnt know if anyone has already found one that works well. Or has one of their own. Budget speed is the name of my game.
Old Mar 2, 2009 | 08:25 PM
homer's Avatar
you can use another slip on map and it should work. if youre not happy with it, just use another one. im using the jardine one right now. just to clarify, i do have the yosh pipe
Old Mar 2, 2009 | 11:53 PM
tomp's Avatar
Just use the full system Yosh map. It will be fine.
Old Mar 3, 2009 | 11:15 AM
sixfive407's Avatar
Yes but I heard if you run the full yoshi map with a slip on it will run tooo lean? Thats what I heard.
Old Mar 3, 2009 | 08:00 PM
homer's Avatar
why would you want to run a map for a full system when he only has a slip on. i belive that i will run rich. just use another slip on map
Old Mar 4, 2009 | 12:03 AM
tomp's Avatar
The only way to get your bike run near 100% effeicency would be to get a custom map. That would be a waste of money in my opinion, if all you are running is a slip-on. Yes a full system map may run rich. You can download all the maps and try out each one and see which map suits your bike. Loading the map from the computer to the PC is very simple.
Old Mar 6, 2009 | 01:47 PM
sixfive407's Avatar
Put full map on just to see and just revn to about6500 started a backfire. Ive got the Jardine map on now and it seems to be a decent fit. Pulls much stronger in higher revs and seems to start power curve about 1000 rpms quicker. I mean I know the dyno be the way to go but moneys tight. I heard that the yoshi header is only like a mm or 2mm difference from stock. Is it the midpipe not downpipe that you gain most power? Header too of course but maybe just midpipe purchase would do a lot. With this new map and the 1 down 3 up its pretty beasty.
Old Mar 9, 2009 | 01:23 PM
RawRR's Avatar
Use the Jardine slip on map. Its the closest to my bike (rr w/rs5 slip on) that they have on their website
Old Mar 10, 2009 | 01:10 PM
DoubleRrunner's Avatar
how much does the power commander cost for an 07 rr????
Old Mar 12, 2009 | 08:41 PM
sixfive407's Avatar
usually about 350 if you search it. go to ebay and search. All powercommanders are the same. They just preload stock map from your bike and give you others.
