NEED Help with the BRIGHT LED turns
Old Jan 3, 2007 | 10:32 PM
wirewalker's Avatar
Default NEED Help with the BRIGHT LED turns
I need some help locating the manufacturer of the "flush mount" casing for our honda 600RR's If I can find them I will produce a full functioning high powered LED turn for our bikes. I bought and modified the "hot bodies" kit. I an useing LED's from a web site. I will not bublish it untill I find their product totally reiable. the product that I am looking to fabricate will fit in our stock set without any modifacation. I have also found a website that has our origional factory electrical plugs. I can do the thermodinamic equasions to figure heat dissapation. I aslo have a guy how can do C.A.D. and aluminum routing. all I need is a source for the outside moldings. anyone who can help would recieve a "cost "discount on one of the very first run's.
Old Jan 3, 2007 | 10:35 PM
knightslugger's Avatar
Default RE: NEED Help with the BRIGHT LED turns
let's hope you don't also write the press release...
so you're looking for the manufacture of the brake lamp assembly?
Old Jan 6, 2007 | 04:48 PM
wirewalker's Avatar
no, the flush mount turn assmbly, the plastic housing.
Old Jan 7, 2007 | 03:30 PM
danny600rr's Avatar
so you need the plastic housing from our stock turnsignals ?
Old Jan 7, 2007 | 03:39 PM
wirewalker's Avatar
no. I am looking for the housing to a "flush" mount turn signal. not the stock signal.
Hustlin Hussy F4I
Apr 6, 2012 11:11 AM
__Z__
Oct 20, 2010 02:41 PM
heybuddy1901
Apr 24, 2008 10:06 PM
voodoochyl
Jul 27, 2007 08:15 AM
icelee
Feb 6, 2006 02:12 PM
