Might be getting a 600RR
Old Oct 29, 2007 | 09:06 PM
anthonyd5189's Avatar
Default Might be getting a 600RR
I might be buying a '03 CBR600RR with 8000 miles and movistar plastics. Dealership is asking 4999, but I'm only going to go as high as 4500...I'm pretty sure they will take that. Any info on the '03s that I should know about?
Old Oct 29, 2007 | 09:15 PM
knightslugger's Avatar
Default RE: Might be getting a 600RR
reg/rect. on the 03 and 04 had heat problems.
Old Oct 29, 2007 | 09:16 PM
What would I have to do to fix the problem?
Old Oct 29, 2007 | 09:47 PM
snag a complete unit off an 05-06
Old Oct 29, 2007 | 10:53 PM
Alright, did this effect all '03? or just some outa the bunch. How willI know that this needs to be done?Maybe the previous owner already did this, I'll look into it.
Old Oct 29, 2007 | 11:13 PM
cbrookie's Avatar
ORIGINAL: knightslugger
does this have anything to do with the hot start problems?
Old Oct 30, 2007 | 12:03 AM
ORIGINAL: anthonyd5189
Alright, did this effect all '03? or just some outa the bunch. How will I know that this needs to be done? Maybe the previous owner already did this, I'll look into it.
it effected a large percentile (and still are) but there is no known way to identify which ones are having problems. what's causing the units to fail is heat from the headers is frying the solid state electronics inside the R/R. now if you live in a cool area, or you mostly do track or highway riding at full speed, chances are you wont have a problem. it's the stop and go, slow though town crowd that are having problems. not enough air getting rid of the heat. the solution is to either retrofit a heatshield to the R/R mount OR find a 05-06 R/R from a junker and install it.
I have yet to determine that conclusion as i have not seen it myself nor have i read it explained very well.
Old Oct 30, 2007 | 01:13 AM
cbrookie's Avatar
hmm... interesting. I ceramic coated my exhaust inside and out and it helped a bit to shed some of the heat and I actually noticed a difference in water temps, but if I sit in traffic long enough at idle when its hot as hell out, I sometime have a dead starter if I shut the bike off when its hot. Oh well...
jjoube84
Aug 5, 2014 06:46 PM
CBRf4iX
Apr 8, 2013 12:39 AM
unit21
Jan 21, 2008 08:31 PM
