Jerking from 03 600RR?
Old Aug 24, 2007 | 07:34 AM
CBRYDR's Avatar
Default Jerking from 03 600RR?
Hey guys,
I've noticed something about my 03 600RR. When I take off, the bike seems to jerk a bit. Is this normally common? Basically, when I take off the line, up to 3-4K RPM
Old Aug 24, 2007 | 08:51 AM
Lrn2Go's Avatar
Default RE: Jerking from 03 600RR?
Not sure why it's jerking... does it do it all the time? Under all different kinds of take-offs? What happens when your cruising along and just dump the throttle? Have you checked your slack in your chain and made sure it's within' specs and not getting chain lash?
Old Aug 24, 2007 | 12:00 PM
CBRYDR's Avatar
Checked with my friend and a Two Brothers exhaust was recently installed on the bike. Plus theres black smoke that comes from the exhaust...The seller says it'll go away after a while. Thoughts?
Old Aug 24, 2007 | 12:33 PM
knightslugger's Avatar
how's your chain slack? within specification?
about the exhaust. does the bike have a PowerCommander installed? Be sure the mapping is correct. what other modifications are done? intake modifications? a slipon will change the fueling ever so slightly. it may run lean at low RPM, perfect at mid RM and super rich at high RPM... you need a PCIII installed to correct thins trend. also, shorter velocity stacks will produce a rich/lean situation as well.
Old Aug 24, 2007 | 01:41 PM
CBRYDR's Avatar
Knightslugger- There is no Power Commander installed. I will be upgrading the air filter though to a K&N, per my friend's recommendation. Now, will it hurt if I don't install a Power Commander anytime soon (i will be running in low RPMs initially btw haha)? Will there be an ECU problem ?(I only say that because I'm relating it to a car. Whenever you install a catback or intake, ECU upgrades are normally performed) Should that be needs for concern? Thanks
Old Aug 24, 2007 | 06:33 PM
ORIGINAL: CBRYDR
If you don't install a PowerCommander, over time your valve train will buildup with deposits and begin to fail. have it installed by a professional DynoJet PowerCommander installer who has a Dyno on site ONLY after you install the K&N filter. DO NOT USE A GENERIC MAP as your bike is unique. DO NOT ATTEMPT TO CHANGE VALUES unless you know what you are doing (and it sounds as though you wont).
Read up on what the Powercommander does. it's not an ECU upgrade, but rather a fuel delivery controller.
Old Aug 24, 2007 | 06:38 PM
CBRYDR's Avatar
If the exhaust is only a slip-on (muffler), do I still need a Power Commander? Sorry for the 20 questions but I need to make sure. I'm assuming if it's a catback, then it would need one but if its just the muffler, is it necessary? Thanks.
Old Aug 24, 2007 | 06:43 PM
ORIGINAL: CBRYDR
I'm not savvy on car talk so i have no idea what cat back means, but either way, the fueling needs to be corrected. if it aint stock, it's messing with your fueling, guaranteed.
Old Aug 24, 2007 | 07:19 PM
Shadowart's Avatar
cars and bikes are two different animals. a slipon would be like a cat back. but on rr you have the 421 headers. so like he said read about the PC3 and look at the different maps then take it to a AUTHORIZED installer and dyno and have it done.. also check your chain slack like he said. u can find the service manual online if you ont already have one.
Good luck man!
