I Need Help PLZ!?
Old Jun 19, 2009 | 12:33 AM
Ocho Cinco's Avatar
Default I Need Help PLZ!?
i have an 03 600rr and i dont know if i need a new battery or i blew a fuse?... my bike will run start but when i try to just turn it on my lights just flicker and there is this flickering noise that comes from my fuse box...can anyone help...thank you!
Old Jun 19, 2009 | 04:13 AM
tkrizzy's Avatar
just take the bike to the local autozone or advanced.... they will test your battery for free. If its the fuse just pull it out, its under the seat, and the connection tab between the two poles will be fried.... if thats the case, most bikes have a spare fuse box right next to it. Typically when a fuse blows your gauges and blinkers will not work. So im thinking your battery is dead. You could also try to just hook it up to a slow charge.
Old Jun 19, 2009 | 08:19 AM
Bullittrr's Avatar
sounds like the battery is too low. Does the fuel pump prime when you turn the key along with the gauges working? If so its most likely battery and not fuse.. ^+1 on the slow charge.
Old Jun 19, 2009 | 01:28 PM
Ocho Cinco's Avatar
thanks alot for the help guys
