How do I know if my starter is bad or not?
Old Nov 26, 2012 | 06:47 PM
HookUp's Avatar
New Member
Default How do I know if my starter is bad or not?
how can u tell on a 2003 600rr if the starter is bad it clicks at the sylinoid
Old Nov 26, 2012 | 06:55 PM
74demon's Avatar
Moved to the correct section, on your own thread.
Old Nov 26, 2012 | 06:58 PM
HookUp's Avatar
New Member
My bad i just registerd trying to figure this forum up
Old Nov 26, 2012 | 08:04 PM
74demon's Avatar
No worries. You'll get it figured our. Welcome to the forum...
Old Nov 27, 2012 | 02:06 AM
Zachy72's Avatar
Well let's start by testing the cheaper, and more common problems here first.
  1. Typically that sound of just the solenoid clicking is a sign of a low battery... if you have access to a multimeter check the voltage across the + and - terminals... i believe (someone else hop in right here) that the voltage to a fully charged batter is either 12.45 or 12.75 volts...
  • No accesss to a multimeter? jump your bike with your car (parents.GF.roomate.stranger)
  • PLEASE MAKE SURE THE CAR IS OFF...everyone is saying that if you jump it with the car on, too many amps blah blah blow a fuse.. never tried it. with the car off is good enough anyways
2. test voltage at the battery side of the solenoid, then again at the side to your started motor (while the start button is being pressed on the control) should be reading ~battery voltage
I highly think it's a low battery though, report back after jumping it
Old Oct 12, 2017 | 04:20 PM
Carrie Merrigan-Johnson's Avatar
Hey, I have a 2008 Honda CBR1000RR Fireblade that currently is not starting. When in neutral and the ignition switch is pressed i hear a click but it doesn't turn over. I can hear the fuel being primed. I've replaced the battery and the Ignition relay as well but it still the same issue. I've checked that there isn't a ground issue and spark plugs were replaced last month.
What would you recommend the next step be for testing? Should I start testing the starter? Any suggestions would be helpful. Thank you.
Old Oct 13, 2017 | 12:39 AM
CaBaRet's Avatar
Have a look at the starter solenoid, maybe bridge it to see if it will turn the engine
Old Oct 13, 2017 | 01:30 AM
Rob2m's Avatar
Make sure it is in neutral prior to doing this.
nvanvlymen
Aug 2, 2011 02:19 PM
EL Thorsby
Jun 1, 2011 03:04 PM
Daniel.Hennessy@va.g
Sep 27, 2008 12:24 PM
rrrobert
Jul 10, 2008 07:56 PM
