help.
Old Jul 8, 2008 | 12:54 PM
Grafiti_600RR's Avatar
Default help.
while installing a fe kit on my 08 600 my buddy accidentally made contact with the brake light wires. now my gauges dont work such as speedo,tach,neutral light,gas meter,and running lights. one of the fuses was popped so we replaced it thinking that might be it but it wasent and when we replaced it nothing worked brake lights turnn signals etc. but when the blown fuse is in my brake light and my turn signals work. im completely lost on what it could be. any suggestions would be greatly appreciated.
thanx, Aaron
Old Jul 8, 2008 | 12:59 PM
skitzofrenzy's Avatar
Default RE: help.
uh check fuses again... un wire and rewire your fe. thats about it for me. also i find that unplugging things and replugging htem in tends to restart or reboot them. try that too
Old Jul 8, 2008 | 01:08 PM
shoortbuss's Avatar
Default RE: help.
It's gotta be the fuse...plug and pray
Old Jul 8, 2008 | 01:09 PM
Blue Fox's Avatar
Retired Moderator
Default RE: help.
I would completely disconnect everything from the rear harness (brake light, turn signals, everything.) Replace the fuse (if it's blown) and check to see if you get all of it back.
