Having problems with my front end
Old Aug 28, 2009 | 01:16 PM
msquires26's Avatar
Default Having problems with my front end
when riding my bike at times it feels my wheel feels like it is loose and wobblie I checked the wheel and its on tight, I checked the tire and it looks fine. I thought maybe it was the road because they r jacked up here. But I was wondering if anybody knows what would cause this.
Old Oct 1, 2009 | 09:29 PM
Soyko's Avatar
Mine does the same thing.
More so when I'm trying to wheelie her in second gear, first gear its fine. Its more of a wobble when I left the front end up.
But the reason why mine is doing that is the small dent on one side of the rim, planning on replacing the front rim next season.
Check if you have dents anywhere also.
Old Oct 11, 2009 | 11:26 PM
amRRussel's Avatar
If the bars have a shake to them when its "wobbling" I would bet on one of two things. You have a broken belt in the front tire. The tire is not balanced either from being bent or dented rim like Soyko mentioned or wierd wear on the tire for whatever reason.
How muich wear is on the tire?
Old Oct 23, 2009 | 04:10 AM
dsrdr's Avatar
you don't if say which wheel it is? front or rear? come on....
if it's front you might need to check your steering stem adjusting nut for tightness
Old Oct 29, 2009 | 10:36 AM
Baooo's Avatar
Post says front end in title
pugzley1986
Apr 30, 2009 12:30 PM
Jaybird180
Jun 22, 2008 09:59 AM
Drewpballz
Jan 24, 2008 04:04 PM
p51
Oct 21, 2006 04:31 PM
p51
Oct 15, 2006 04:43 PM
