Exhaust flapper Mod?
I had my flapper removed completely when I had my bike tuned. (They added block off plates, retune, flapper delete) Not much to be gained by just removing, I'd imagine.
ok, I'd like to change my answer please
Hahaha, sorry. I did a COMPLETE removal. The motor, the cables, all the stuff on the outside of the exhaust, and I even removed the valve and cut the shaft out, then plugged the holes.
Its not amazingly better, but its definitely a bit louder above 9k, and pulls harder up there too.
Looks like you have your answer then. I didn't know much about velocity stacks on this bike, but I did find this while researching and wanted to share:
https://www.superstreetbike.com/hond...ack-mod#page-4
those are just modified/swapped around stock plastic pieces.
Venturi, TenKate and Factory Pro are all proven to make more power and allow the bike to make power right to redline.
Not huge numbers on stock bikes, but useful. And once you are not stock anymore, they keep on making more power.
