Laggy...
RE: Laggy...
Hmmmmmm, I know these bikes flapper mod or not tend to do that anyway...but mine has become way more apparent since I did the wide tire kit and stretch, this being beacuse of the added weight to the bike and added rotating weight, plus a slight delay i imagine in the much longer chain. I wonder, if I undo the flapper mod will that help me get some torque back? Comparing it to a car...if you run a large intake manifold, its good for hp #s but lowers torque. Is this kinda the same thing???
RE: Laggy...
I dunno -- I completely removed my flapper (if you think the hose is a bee-yatch you ain't seen nothing) and the low end throttle response and slight hesitation went away completely. Best bang for the buck ($0) I've done on this bike.
You need to post up in the " Mods that don't work or were not worth the $ " thread that's going around now and let peeps know that it didn't work out for you personally.
Something that a lot of us forget is that even though these bikes are made outta the same parts going down the same assembly lines they are each a little different and some will not take to certain mods as well as another will. Doesn't really make sense but sometimes it works that way.
