eliminate secondary injectors?
My current project is using a 600rr engine. The height of the engine and airbox is critical. The lower the better. The secondary / upper injectors are requiring me to add about 9 inches to the height of the engine. Is it possible to eliminate the secondary injectors programatically with a new map? Performance is important, but not the most important consideration with what I am working with. I do realize the secondary injectors are used at upper rpms and I would be sacrificing upper engine rpm performance.
My plan was to only use the primary injectors if I can eliminate the computer call to use the secondary.
My other bizarre question regards the guage cluster. Currently the computer needs it to run. Does anyone know of a way to bypass this requirement as other guages are being used.
Thanks in advance.
[IMG]local://upfiles/24389/592ED29E23654F0090764AFBE86645A0.jpg[/IMG]
Thanks in advance.
