Electrical problem
Old Sep 8, 2008 | 10:23 PM
rookie600rr's Avatar
Default Electrical problem
Hi Buddies,
I have a strange electrical problem. Both headlights are not getting power.
I have checked all fuses at least three times, the fuses are still good.
This has happened three times in the last week. The first time I fixed it by reseating the fuses. The second time it fixed itself by the time I got the fuse box opened. This time I can't fix it by checking the fuses or wires.
I've tried jiggling all wires and connectors I can get my hands on.
All gauges and indicators, turn signal, horn, marker and brake lightsseem to work.
I'm not familiar with the wiring scheme so I don't know what else to check.
Did anyone have a similar problem?
I hope I can fix it soon.
Thanks.
'05 600rr
Old Sep 8, 2008 | 11:45 PM
carbonrrpilot's Avatar
Default RE: Electrical problem
most bikes have a headlight relay which usually feeds both hi/lo beam, find out where yours is, hold it in yer hand then turn the key on you should feel it click, if not, the relay is bad ! the relay can click but still be bad, but itsunlikely!
Old Sep 8, 2008 | 11:46 PM
Hatebreed's Avatar
take the plugs that go into the bulb and make sure they are still good.they might be bent or burnt or somthing,.
01daell
Sep 2, 2021 07:46 AM
kwood
Jun 1, 2020 09:53 AM
vfrman
Nov 16, 2008 10:06 AM
hridlehuber
Apr 5, 2006 04:11 AM
dunn929
Dec 6, 2005 12:50 PM
