dammit!!
Old Apr 2, 2006 | 02:32 PM
bigboiRR's Avatar
Default dammit!!
so im out trying to get a feel for my new bike and doing the paking lot stuff, never really leaving first gear. So i've had enough and time to head home and everything is good till i pull up to the curb to put my bike on the sidewalk(city living), I dont even touch the curb and i go down on the right side not hard very slow just layed the bike down, other than looking like a jackass i have two problems 1) the hoses on the left side near the kickstand were leaking, what exactly was the fluid comming out and do i need to replace stuff 2) the front brake handle is slightly bent down, how bad is this and what can i do to correct/replace it? thanks for the help but for now im gonna go cry a little bit dammit!!!
Old Apr 2, 2006 | 02:52 PM
city worker's Avatar
Default RE: dammit!!
[:@] that blows dude!! check the fluid is it anti freeze?? or motor oil??? it can tell you more of what to look at closer, the brake handle you can try to bend back or replace it, good luck bro, I'll cry for you also
Old Apr 2, 2006 | 03:23 PM
CMHGUY's Avatar
left side near the kickstand........could it be the overflow from the battery?? Might want to check that as well..... as far as the break handle.....if it works use it until you can replace it..... TAKE it easy!
Old Apr 2, 2006 | 03:45 PM
dwhite645's Avatar
yeah, that sucks. It sounds like that is your run off hoses that are leaking. No biggie if that's the case, they just drain overflow.
Old Apr 2, 2006 | 08:07 PM
bigboiRR's Avatar
yea it was just my over flow, and the brake is fine just a little bent but still works fine. I really am trying to take it easy, just difficult to wait 3 months for my msf and the bike is just chillin out front. Im only taking it around the block and what not till then but i appreciate your help fellas Thanks
Old Apr 2, 2006 | 10:24 PM
LTVN68's Avatar
Compassion from me......my new 600 rr walked off by itself, collapsed its kickstand and fell. Never leave the bike running by itself on the kickstand if the bike is on a slight downhill.......I found that out, brother!!! I had stood back from it to put my helmet on.[:@]
Old Apr 3, 2006 | 11:09 AM
josho66's Avatar
Sorry to hear that. []
Old Apr 3, 2006 | 01:53 PM
HighRevver's Avatar
I'm confused, are you saying that you laid it down and bent the front brake(right side) and are worried about some hoses leaking on the left side from the lay down?
OR are you saying on a side note the left is leaking?
Old Apr 3, 2006 | 06:32 PM
bigboiRR's Avatar
LTVN68, that sucks, appreciate the compassion it was the worst i was watching the thing go down and there was nothing i could do, I cant imagine watchin it roll away, your heart must have just sank, but thanks for the tip!!
Old Apr 3, 2006 | 06:59 PM
latinoheat31's Avatar
ouch that sucks man, should be an easy fix just think of it as getting to know your bike a little more when you get to take a closer look lol
skribblah
Aug 10, 2008 09:13 AM
compulady5
Apr 10, 2007 12:03 AM
voodoochyl
Nov 3, 2006 12:50 AM
Losi1000F
Aug 6, 2006 10:16 PM
