To cut, or not to cut...
Old 11-26-2005, 01:52 PM
techdog's Avatar
Default To cut, or not to cut...
That is the question. Ok so I put on my TwoBrothers pipe, but when I was playing with the heat shield I decided to keep it on. One reason was because I wanted my girls butt to not fry. The second reason was because I wanted to make sure the plastics did not get damaged. The third reason was because when my buddies and I went to vegas, a friend rode his R1 and it does not have any heat shield. He had blisters on his leg when he got to vegas. So now I pose the question to the group. Cut, remove or keep the heat shield?
[IMG]local://upfiles/1375/8D908EE3096145C1AB09CC791D45CB15.jpg[/IMG]
[IMG]local://upfiles/1375/A5A258CE647442088F3085BA963181CF.jpg[/IMG]
Old 11-26-2005, 02:19 PM
Default RE: To cut, or not to cut...
sounds like you alrady know what you think you should do. I think it looks pretty clean as it is anyway.
Old 11-26-2005, 06:44 PM
I agree cjbettis, it doesn't look bad with the heat shield so I'd stick with it.
Old 11-26-2005, 07:30 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Take the heat shield off and paint it gloss black -- use some high heat paint if you can find it.
Old 11-28-2005, 03:13 PM
just trim it a little in the back end.
Old 11-28-2005, 03:30 PM
wonder how it would look to cut the sides off...... so you can see the pipe! And then paint it black....
Old 11-28-2005, 03:32 PM
L8X's Avatar
L8X
L8X is offline
i took off my heat shield completely and didnt have a prob with anything melting.
Old 11-28-2005, 04:26 PM
doncollins's Avatar
Retired Administrator
L8X... how long has yours been cut, and how long do you ride? I think chain had a great plan, paint it gloss black with exhaust manifold paint. It withstands temps in the 1200+ range depending on the brand.
Old 11-28-2005, 05:35 PM
I don't think I mind the heatshield too much. Of course I don't have an exhaust either, but, I don't think it would bother me. If you really wanted it off, I haven't heard anything bad about it really. It's the first time I've heard of people's legs blistering up.
Old 11-28-2005, 11:26 PM
I don't use the heat shield. I got the yoshimura RS-5 no problems with things melting or getting hot.
