Cooler Temp
Old May 5, 2006 | 11:36 PM
Frerice's Avatar
Default Cooler Temp
I know that the Hondas (2006 CBRs) can run hot (i.e. ~210 F at idle). Is there anyway I can get'er to run 10-15 degrees cooler. I commute to work on a daily basis and we are starting to get warmer on the East Coast. We know the right cheek can get warm
Is there an aftermarket thermostat or something?
Old May 6, 2006 | 12:18 AM
woodyracing's Avatar
Default RE: Cooler Temp
running water and water wetter can help with cooling, but keep in mind you'll need to change it back to coolant before winter
Old May 7, 2006 | 05:00 PM
FordFrenzy97's Avatar
I live in florida and have the same problem. Can I run straight water or do I have to run antifreeze?
Old May 7, 2006 | 05:16 PM
like I said you can run water with Water wetter, running straight water is bad for the cooling system, the water wetter keeps corrosion from occuring
Old May 7, 2006 | 05:31 PM
Way2Cool's Avatar
yup +1 on that
Old May 7, 2006 | 08:07 PM
isolated1523's Avatar
Retired Super Moderator
my RR has been runnin really hot lately....unless i'm movin pretty good, it rarely drops below 195-200. Lately when in town i've seen 228-229. I think that i may have too much coolant and not enough water in there....would you suggest draining a fair amount of the coolant and adding distilled water?
-Adam
Old May 7, 2006 | 08:14 PM
that would probably be okay, just make sure when winter comes around again you have the proper ratio so you don't end up with a busted cooling system
If you haven't changed the coolant in a while you might go ahead and flush the system and add all new coolant and water.
Old May 7, 2006 | 08:15 PM
oh and anybody that replaces their coolant with water wetter make sure to flush the whole system a few times before adding the water wetter/water so you don't still have regular coolant mixed in with the water/water wetter
Old May 7, 2006 | 08:39 PM
13brsxsrr's Avatar
ORIGINAL: woodyracing
+1.
Also run distilled water and not tap water. It will aid in cooling better than tap water and won't deposit sediments in the system.
Old May 8, 2006 | 04:05 PM
VegasD's Avatar
I have an 05 and I run Engine Ice and I have found that it usually stays around 220 and I'm in Vegas, It heats up faster but also cools faster when riding. The highest my bike has been is 230. I havent seen anyone suggest this, is Engine Ice no good?
