cbr rr 600 (2003) led flasher relay HEEEELP
Old Aug 14, 2008 | 06:59 AM
poulteren69's Avatar
Default cbr rr 600 (2003) led flasher relay HEEEELP
hi there,
i have a 2003, honda cbr rr 600.
I have had some led indicators put on the back and front. My garage has told me they wont flash (and they dont) unless i get a "four pin flasher relay for LED indicators". I have looked everywhere and can only find, 1, 2, 3 pins. PLEASE can someone help. as i'm very lost
I have been trying for ages and am getting so frustrated.
thanks,
Ed
(edward.p@gordian.co.uk)
Old Aug 15, 2008 | 07:56 PM
Blue Fox's Avatar
Retired Moderator
Default RE: cbr rr 600 (2003) led flasher relay HEEEELP
You can't replace the flasher relay on 600RR's. Just go to Autozone or Checker's and get a pair of LED load resistors and wire them in as per instructions. You'll get the "fast blink" if you wire one resistor per side. If you put a resistor on each signal, you'll get the stock blink rate back.
Old Aug 15, 2008 | 10:05 PM
importcarkid's Avatar
I recomend hard wiring a Flasher Relay instead of using resistors. here is a link on how do it.
http://www.600rr.net/vb/showthread.php?t=52311
Old Aug 16, 2008 | 01:36 AM
Blue Fox's Avatar
Retired Moderator
^^ GREAT LINK, But he took the bike to a shop to get the signals installed, so I doubt he would want to dive knee deep into taking apart the bike, and cutting into main harness on his meter cluster. But either way, that's a great write up and great link. Good find.
On a side note, 07/08 600RR's do not need any sort of resistors for the "fast blink". LED signals with work just fine on the 07/08's without resistors, unless you want to retain the slower stock blink, then you have to wire in 4 resistors (1 per signal)........with Rizoma's anyway.
CJardine
Apr 3, 2012 08:51 PM
Jerzdan
Jul 15, 2009 09:38 PM
muckdawg24
Sep 17, 2007 12:13 PM
benp26
Jun 29, 2007 08:28 PM
elbaguy
Dec 20, 2006 04:24 AM
