Honda cbr600rr 2008 huge problem!!
Old 01-21-2018, 04:51 PM
johnfi91's Avatar
Default Honda cbr600rr 2008 huge problem!!
Hey guys!!i would need your help!!I have a 2008 cbr600rr with 38000km..my bike is in very good condition!!before three days a problem appeared..as I was out for a ride I stopped to buy something and when I went back to the bike it didn't started right away..I didn't give much attention because It ride really well the rest of the day..tomorrow the problem got worst!!!the bike started in the morning without problem but after a little while that I went to started again it didn't fired up!!
THE PROBLEM:when I am turning the key the bike turn on but the hiss, fi and the hesd lights stay on..pump doesn't prime!!as I was searching around for a possible cause because I had some problems with the stop button before I cleaned some connections..the start button and the hiss connection..after that my bike started..I turn in off and try again and the same happened..as I was searching for the problem again I moved a little the starter relay I hear the pump priming and the hiss fi and hesd lights turn off..the bike started right away..I turn in off turn it on and the same problem again..I touch the connections at the same spot and the pump primed again!!I tried one more time and this time the bike didn't start..I was there for 1-2hours but nothing happened..today I went to the bike and it started right away..I went for a ride and the bike run great!!no problems at all..I came but home turn off..and when I turn it on the same problem was there!!pump didn't prime hiss fi and hesd lights on!!what do you think it's the problem?
Old 01-22-2018, 01:41 AM
CaBaRet's Avatar
Would have a look at the safety connections , Clutch ,BAS, side stand switches maybe just clean them up with WD ELECTRICAL spray , sounds like a poor connection somewhere
Old 01-23-2018, 04:25 PM
johnfi91's Avatar
i found the problem!!it was a snapped cable at the main switch!!
Old 01-23-2018, 04:29 PM
Rhondasoulsoothinghonda's Avatar
What can said mate
myfreshdcs09
F2 Tech
05-27-2011 11:31 AM
canhead64
04-15-2010 11:41 AM
Harry_T_Hamster
05-26-2008 12:53 PM
JC00
03-14-2008 09:54 PM
skin129
12-27-2006 02:32 AM
Quick Reply: Honda cbr600rr 2008 huge problem!!
