Brake light and right turn signals not working
Old Jul 29, 2023 | 05:48 PM
rivesw's Avatar
Default Brake light and right turn signals not working
Hey guys, new to the forum and thank you in advance for any insight.
2004 600rr.
owned the bike for years. Bought it with after market led front turn signals and an integrated tail light/brake light/turn signals. Everything has worked fine for years and then I let it sit for the past few years, now I have a problem.
The brake light works fine.
The left turn signal works fine.
the tail light doesn’t light up at all.
The right turn signal has an issue. If you initially turn the right signal on no lights illuminate except for the right signal light on the dash is on solid (not flashing). It will continue to behave this way until you turn the left signal on, the left signals work (front, rear, and dash) then switch to the right again and the right signal flashes on the dash (like normal) but no signal lights illuminate on the front or rear. All fuses are good.
Thoughts?
iwishiwasonfire
Jun 25, 2011 02:32 AM
FightasCBR600
May 26, 2011 09:09 PM
600cbr18
Mar 2, 2011 12:04 PM
NickV
Jan 22, 2010 08:46 PM
wande00
Sep 27, 2006 07:39 PM
