Brake Light Always On - Already tried adjusting the switch
Old Jul 10, 2013 | 01:28 PM
ChrisTam's Avatar
Default Brake Light Always On - Already tried adjusting the switch
Hey everyone. I'm new to this forum and I just bought a 2004 cbr600rr yesterday. My first supersport. I've been riding dirt since I was 3 and had an Sv650s before this (which I'm trying to sell).
Anyways... So when looking at the bike I found that the brake light did not work when the brakes were pressed. I thought it wasn't working at all. However, it seems as though the brake light is always on. I have disconnected both brake switches to try and find which one is the culprit and it seems as though both are allowing the brake light to always be on. With the front brake, the switch isn't being pressed by the lever (easy fix - except I also dropped the screw in the middle of the bike). However, with the rear one if it is even plugged in the brake light is on. I have tried adjusting the little black plastic switch sensor thing and no matter how loose (or tight) it goes, the brake light is always on.
Help would be greatly appreciated. Thank you in advance!
Old Jul 10, 2013 | 01:31 PM
74demon's Avatar
Does the rear switch slide easily? Try giving the shaft a little wd shot.
Old Jul 10, 2013 | 01:36 PM
ChrisTam's Avatar
Just saw your response and tried it. Still always on.
Old Jul 10, 2013 | 01:38 PM
74demon's Avatar
Does it slide?
Stock tail light and wiring?
Old Jul 10, 2013 | 01:42 PM
ChrisTam's Avatar
Yes it is sliding. It has a fender eliminator kit. I'm not sure which one. I'm pretty sure the tail light is stock though. I took all the fairings off to check the wires and whatnot (and to clean the bike) and everything looks fine as far as that goes.
Old Jul 10, 2013 | 02:12 PM
74demon's Avatar
Measure continuity through the switch in the open and closed position. If it never breaks the circuit, you have a bad switch.
Old Jul 10, 2013 | 02:23 PM
ChrisTam's Avatar
Okay will do. Thank you very much for taking the time to respond!
Old Jul 13, 2013 | 05:53 PM
ChrisTam's Avatar
Somehow I fixed it. I just disconnected the rear switch and was just using the front. I then tried connecting the rear brake switch again and now it works just fine.
Jeffcbr600f2
F2 Tech
Jun 28, 2012 04:11 AM
mpbigham
Oct 20, 2006 02:11 PM
Johnny954
Sep 5, 2006 10:50 PM
CivicRacerX7
Jan 9, 2005 11:13 PM
