blinkers not blink
Old Jun 26, 2009 | 09:24 PM
stillloco's Avatar
Default blinkers not blink
ok heres the deal.... i was told my rear blinkers are not bright. so i bought some led ones installed them right n they go on but dont blink any idea? maybe there cheap n need to buy better ones got them from ebay 30$
Old Jun 26, 2009 | 10:43 PM
raiden's Avatar
are u talking about rear signal light? or is it just accesories ?
Old Jun 28, 2009 | 04:23 PM
Boiler_RR's Avatar
ageed with above, is it integrated or actual signals? prolly missing the relay wire
Old Jun 28, 2009 | 05:25 PM
stillloco's Avatar
its the hole rear turn signals there leds. looks like the stock ones, just a bunch of leds in one
Old Jun 30, 2009 | 02:03 AM
philthethrillohio's Avatar
mine does the same thing, but will start to blink sometimes? whats wrong with mine?
Old Jun 30, 2009 | 08:19 PM
stillloco's Avatar
ok was told that
It sounds as if there isn't enough resistance (Power draw) to trip your flasher relay. This usually happens if you have LED's on the front and rear or you are only running one set of lights.
There could be several solutions to this:
1. Add resistors to increase the resistance and trip the relay.
2. get a flasher relay that doesn't care about current drop
3. add more lights to draw more electricity.
can someone point me into the right direction
Old Jul 1, 2009 | 10:07 PM
this makes a lot of sense. when i bought the bike the gauge cluster would go out due to the fuse blowing. i took the bike apart and found a set of lights hooked to the ked turn signals. so i disconected them and the speedo is fine and has been for over 1000 miles. havent blown a fuse yet. but now the signals are static, they dont blink , well sometimes they do but 9 out of ten they dont. solution?
__Z__
Aug 12, 2010 06:45 PM
JB50
Oct 3, 2007 12:39 AM
christopher
Feb 9, 2007 01:36 PM
