Bike wont start?
Old Aug 17, 2017 | 03:13 PM
Supersport600's Avatar
Default Bike wont start?
Had the bike sitting for awhile wouldnt start or charge. Went out and bought the same battery duralast gold ready to ride, hooked up jumper cables it started and i took it for a ride. Got back home and shut it off and tried to start it up again and it wont turnover whats the problem? Never had a problem with it intil it sat for a couple months.
Old Aug 17, 2017 | 07:17 PM
74demon's Avatar
Did the battery come charged?
Old Aug 17, 2017 | 11:18 PM
900rrGuy's Avatar
Sounds like a bad rr
Old Aug 18, 2017 | 03:15 PM
yeahi bought the same battery it had before. The bike started yestarday and i tried to start it today and it just clicks i think something draining it but im not sure
Old Aug 18, 2017 | 03:36 PM
only has 6k miles never had a problem till i got a new battery
Old Aug 18, 2017 | 04:25 PM
74demon's Avatar
Why did you need jumper cables to start it with a new battery? Some department store batteries require charging before use. Could even be old stock...
The clicking points to low voltage.
Old Aug 18, 2017 | 05:20 PM
i put the new battery in and it still wouldn't start i forgot to say i did put it on a trickle charge and let it sit over night but still wouldnt start so i jumped it the battery i got said it didn't need an additional charge. I checked it with a mulit meter and it would be at 12v but still wont start Could it just be a bad battery ?
Old Aug 18, 2017 | 06:13 PM
74demon's Avatar
Could be. Look and see how low the voltage gets while attempting to crank it.
Old Aug 27, 2017 | 11:59 PM
Shawn Roblee's Avatar
Default same exact problem but i know da answer
I have an 03 cbr 600rr and i bought it used... Didnt think much of it. But like you i ran into some battery issues ... I know you probably already heard tbis but check if your recharge system is working if it is then its your battery .... Trust me man i had the same issue ... But i dropped 700 on a new stator and that lil module that changes ac to dc....when i continued to have problems i found out that the brand new battery i bought (not even a week old) didnt have enough cranking amps ... Havent had a problem with it sence for charveing anyways
C Jacob W
Jul 29, 2013 11:03 AM
CTcbr929
Jul 31, 2009 12:25 PM
tagger609
Jun 27, 2008 02:09 PM
mishab
Sep 7, 2007 01:00 AM
