Bike seems sluggish after oil problem
Old May 24, 2011 | 08:20 PM
prodkey05's Avatar
Default Bike seems sluggish after oil problem
I was riding my bike today and the oil cap somehow backed its self out and came off. I pulled over and shut the bike off after my little oil bath(bike only ran a max of 10 seconds with the cap off.) I went and got some oil and filled it back up.(no I didn't drive the bike there). Got it back to the full mark and headed home. Its only about 2 miles. I thought maybe from re vibration at higher rpms caused the cap to come loose so I decided to crank her wide open. I throttles it wide open in first and it seemed sluggish so I let off and it seemed like the rear tire wanted to lock up( it acted like ABS on a car when you hit real hard). I then tried it again in a higher gear and it just seemed real sluggish like somethin was holding it back. Is it caused by what happened with the oil. I also got gas could it be bad gas. I recently changed the sprockets also to +1 -2. Any help is greatly appreciated. I vowed not to ride it anymore until I change the oil with good quality oil and new filter. Also its not making any knocking or pinging noises. Everything sounds good and I know what a bad more sounds like and everything sounds good.
Old May 24, 2011 | 10:54 PM
champ24's Avatar
How much oil came out? Even 10 seconds is enough to mess up your engine if it isn't getting oil.
Old May 25, 2011 | 06:22 AM
prodkey05's Avatar
Not to much oil came out.Could it possibly be that I put to much oil in. I thought oli could see it in the sight window bit it was dark and I was using ny cell phone to see. Maybe I did put to much oil in and from talking to people that would make it sluggish like that. Or the ethanol that is in the gas. I filled up at a sheetz
Old May 25, 2011 | 09:24 AM
R Dub's Avatar
October 2011 ROTM
When you filled the oil was the bike upright or on the kickstand?
Old May 25, 2011 | 09:37 AM
prodkey05's Avatar
Kickstand
Old May 25, 2011 | 09:38 AM
DammitMike's Avatar
If you went +1 front and -2 rear the bike would have slower acceleration.
Old May 25, 2011 | 10:16 AM
R Dub's Avatar
October 2011 ROTM
oh yeah true that. I read that and must have just thought he meant -1 and +2
Old May 25, 2011 | 11:06 AM
prodkey05's Avatar
That's what I did mean I wrote it wrong. You guys were right -1 +2 is correct
Old May 25, 2011 | 11:59 AM
R Dub's Avatar
October 2011 ROTM
Change the oil and make sure that the bike is upright when you fill it up, not on the kickstand.
Old May 25, 2011 | 12:50 PM
ahbrown4057's Avatar
Yeah from the sounds of it I'd agree with RD - flush that **** out and hope for the best! I think everything will be fine bro
