best mods to do first on 05 600rr
Old 12-12-2005, 08:25 PM
pirateoftheCBRRRRR's Avatar
Default best mods to do first on 05 600rr
I know don has got the same bike as me but I am looking for the best mods to do to my girl first, I was thinking a yoshi rs-5 but frame sliders are the major concern any suggestions??
Old 12-12-2005, 08:37 PM
Default RE: best mods to do first on 05 600rr
Frame sliders are good as long as you're ok with cutting the plastic. Drop a tooth on the front sprocket.
Old 12-12-2005, 10:45 PM
Tahoe SC's Avatar
frame sliders!
if you're a noob, do not drop a tooth on the front sprocket just yet.
Old 12-12-2005, 11:16 PM
first bike man so bear with me, what the hell is a tooth??
Old 12-12-2005, 11:30 PM
1) set up your suspension to suite you (sure you already did but in case you haven't)
what are you trying to do? performance or look?
Old 12-13-2005, 12:57 AM
doncollins's Avatar
Retired Administrator
ORIGINAL: pirateoftheCBRRRRR
He’s talking about gearing... change your sprockets to get more torque. The stock gearing is 16 front 43 rear, if you go to 15 or 14 in the front or +2 +4 in the rear, you get better take off... but loose some top end. This will also cause your speedo to be off.
Old 12-14-2005, 02:34 PM
Tahoe SC's Avatar
and with a first bike...too much jerk.
don't do it until you get a better handle on the throttle (ie. throttle control).
Old 12-14-2005, 07:27 PM
adjust the levers and controls to fit you best, that wil help alot with learning the control and remember....
comfort = confidence
Old 12-14-2005, 07:30 PM
also some flush mounts front signals will minimize the chance of cracking the plastic if you "drop" the bike. The stock signals have alot of leverage and will break the plastic most of the time, that with some frame sliders will minimize any damage that may come fom a simple drop.
There are only two types of riders, those that have dropped a bike and those that will drop a bike
Old 12-20-2005, 07:29 PM
right on with the last sentence
Quick Reply: best mods to do first on 05 600rr
