another tire question..
Old 05-31-2006, 11:38 PM
RiceRR's Avatar
Default another tire question..
okay i need a new back tire.. i dont ride really aggressive..yet...the tires im choosing between would be the 190/55zr17's or could i get a 190/60Zr17 diablo strada? i would also like to know how much of a differnce is a 190 worth over a 180.. whats the difference between 50,55,and 60...? sorry for the newbish questions
Old 06-01-2006, 12:32 AM
Default RE: another tire question..
I would stay with the stock size. If you change, it may affect handling. As far as the numbers, the 190 is your width in mm and the next number is the height of the sidewall compared to the width. Say you have a 190/55-17, That means the sidewall is 55% the width of the tire (55% of 190mm). And of course 17 is your rim size. Someone please corect me if im explaining this wrong. Again though, I would stay with the stock size.
Old 06-01-2006, 02:20 AM
If your asking about tires..then the best bet is to stick with sotck size because as mentioned it will affect handling and it may make things a lil more hectic with the swing arm going with a wider tire..
Old 06-01-2006, 05:48 AM
RiceRR's Avatar
i know 190's fit. guy in town has a conti on his rr... has anyone jumped around with sizes???
Old 06-01-2006, 06:27 AM
ORIGINAL: RiceRR
Yeah, it'll fit but it doesn't mean that it's right. If you squeeze a wider tire on the same rim, the center contact patch is now more narrow since the section radius has changed, ride height and geometry will also be compromised. Stick with the 180/55zr17
Old 06-01-2006, 07:06 AM
RiceRR's Avatar
okay but now for the question.. maxxis supermaxx's or pirelli diablo strada or Metzeler Sportec M1 Supersport's.. i myself am leaning towards the diablo's.. ive read good reveiws on these...
Old 06-01-2006, 09:58 AM
Does this look familiar:
WARNING: Installing improper tyres on your motorcycle can afftect handling and stability. This can cause a crash in which you can be seriously f ucked or KILLED. Always use the size and type of tyres recommended in the owner's manual.
Front:
120/70zr17m/c (58w)
Dunlop: D128FK
Michelin:: Pilot SPORT E (except U, MX type)
Bridgestone: BT014F Radial E
Rear:
180/55zr17m/c (73w)
Dunlop: D218k
Michelin: Pilot SPOT E
Bridgestone: BT014R Radial G
Type: radial-ply, tubeless
Old 06-01-2006, 11:26 PM
ORIGINAL: ashsammy
Front:
120/70zr17m/c (58w)
Dunlop: D128FK
Rear:
180/55zr17m/c (73w)
Dunlop: D218k
I think I've seen this one before
Doesn't a wider tire effect your turning?
I think wider tire will add to your Bling Factor!
Old 06-02-2006, 05:32 PM
RiceRR's Avatar
no not familiar.. but then again i only browsed the handbook..yes i stayed stock size. But then again the handbook says to not do alot of stuff... anyways. i ordered a 180 55 17 diablo strada. oh and an icon hat.. should get it monday and have the tire on tuesday. anyone ever had a pirelli? pros cons?
Old 06-02-2006, 10:42 PM
Switching to a 190 rear is possible and is pretty much a track/race thing and it's suppose to give improved turning and grip, but you can't just spoon the tire on and expect it to work great for you, you have to do some suspension changes to get it to work right...for the street, I'd stick with stock.
Quick Reply: another tire question..
