Air Pressure for Track Day
Old 08-26-2007, 12:11 PM
markskow's Avatar
Default Air Pressure for Track Day
I'm looking for recommended tire pressure for track use. I'm riding an '07 600RR with Dunlop Qualifiers and I weigh in at around 220lbs. My 1st track day is coming up and I'm just looking for a good starting point.
Old 08-26-2007, 02:12 PM
rolandk's Avatar
Default RE: Air Pressure for Track Day
Ask around when you get to the track. Not much help but the Pirelli guys recommend 33 front and 31 rear for Corsa III's at Portland.
Old 08-26-2007, 02:23 PM
the michelin rep told me at the last day i did that you need to get your cold psi and then check again when you get back to the paddock
if it is over a 5psi difference you dont have enough air
if it only a 2-3 difference you have two much air
Old 08-26-2007, 03:55 PM
ORIGINAL: rolandk
thats a lil high... i dont know the track your on, but me and my buddies run 29-27 front and than -1 in the rear.
Old 08-26-2007, 03:56 PM
o those are on all sorts of tires though, corsas, PP 2ct and some others
Old 08-26-2007, 04:53 PM
go as normal and ask the tech at the track when you do your inspection...they'll know the best...Have fun at the track!!!
Old 08-26-2007, 06:31 PM
meanstrk's Avatar
Corsa III's run a higher recommended pressure than others. For the Qualifiers, I use 30/30 when using warmers or 32/32 when not using warmers.
Old 08-26-2007, 10:40 PM
markskow's Avatar
Thank you all for you're help. I just want to keep the rubber where it belongs. Thanks,
Old 08-26-2007, 11:40 PM
meanstrk's Avatar
The only lowside I ever had on a track was due to cold Qualifiers and is why I run warmers now. Make sure you take it easy for a lap or two each session to warm them up!
Old 08-27-2007, 06:00 PM
ORIGINAL: meanstrk
thats good to know, i am running qualifiers for the first next track day
the pilot powers on my 1000rr at 40 degrees and raining would still stick like glue
Quick Reply: Air Pressure for Track Day
