94 honda cbr 600 no spark
Are you not getting any spark from both coils or just one? Do the coil tests on page 16-7 to make sure your coils/ spark plug wires are in spec. I'm guessing you've checked all fuses and the bike turns over when you go to start it. I agree with CaBaRet check all safety switches
If you want to help me out could you run the ignition primary coil test on page 16-6? It's done at the cdi (icm) with it unplugged I'm getting 4.3 ohms and have no spark I'm thinking that could be my problem manual calls for the max of 3.1 ohms just want to see some real world numbers to see if I'm that far off of a running bike
I'm in the same position same bike maybe we can hep each other out, first why did you change your cdi (icm) did you fail any of the tests in the manual page 16-6? And what'd you do with it I might be interested haha
i have 2 94 cbr 600 and I took the cdi off the one that was running and put it on the one that's not but at the moment I'm looking at side stand switch neutral switch again
