600rr fork options w/ 05+
After crashing my CBR at the track again, this time the lower clamp & right fork tube bent. Just curious has anyone attempted to do a fork conversion and put the 05+ forks on an 03-04 model 600rr? Not sure if the stem part of the frame is the same size or not. If anyone has any info or knows where any is please point me in the right direction.
Before
![Name: tmjennings3.jpg
Size: 80.6 KB](https://cbrforum.com/forum/attachments/cbr-600rr-12/81312d1501380875-600rr-fork-options-w-05-tmjennings3.jpg)
After (Highside on turn 8 @ Jennings) Lucked out with a fractured thumb! Didn't get my butt far enough off the seat and drug my frame slider, pivoting the rear wheel up [&:]
![Name: DSC_0206-2.jpg
Size: 106.8 KB](https://cbrforum.com/forum/attachments/cbr-600rr-12/81313d1501380875-600rr-fork-options-w-05-dsc_0206-2.jpg)
Being a noob sux [8D]
Before
you need the conplete setup, forks triples clipons, the triples fit the frame the same way but the newer forks are inverted and wider at the top so everything that clamps onto the forks must be replaced, oh almost forgot you need the calipers too, the rotors are the same
