600rr 2004 feul pump 11,1 volt? not working ?
Old Oct 31, 2018 | 10:08 AM
mustangharrie's Avatar
Default 600rr 2004 feul pump 11,1 volt? not working ?
bike wont start , starter is turning over good . battery 12.8 volt . everything is working , dash , lights everything works . kill switch no cliking sound , but relay is working . no fuel pump sound .
feul pomp connectors is reading 11.1. volt. ( black wire .red wire ) pump is then not working . when i ad 12 volt onto it , it works .
front relay onto the air intake left side , is reading nothing ? exchangest the relay but stil nothing ?
11.1 volt wil not work for the feul pump ? why do i get 11.1 volt ?
Old Nov 1, 2018 | 07:36 AM
solved 1 problem . tilt sensor error . next problem . everything works now . but fuel pump stil not working . pump is ok wen adding from battery 12 volt and negative . connector from engine to fueltank messering negative and 11.8 volt . connecting the wires , i messering from the output connector from fueltank , no volt ?
when putting 12 volt from battery onto fuelpump bike starts and runs direct and good .
next strange thing ,,,,,only adding 1 cable 12 volt from battery to fueltank connector and pump is running ? without negative cable ?
do i have a fault connection into my fuelpump ?
connector from bike the pump messering 11.8 volt and negative . connect to pump , nothing works ? adding from battery direct to pump 12 volt and negative , pump runs . connecting the cable from bike to cable from tank , i messering no volt ? disconect the connectors and i messering 11,8 volt and negative onto the connector xomming from the bike ?
ad only 1 cable 12 volt onto the fuel cable and pump is running ? no negative ?
how is this possible ?
Old Nov 2, 2018 | 01:19 PM
bike runs , like normal , but put a new wire from fuel relay to fueltank connector and a new wire for minus , did only connect the wire for empty tank onto the orginal connector from fueltank to bike , turning the key and fuelpump is running 5 sec , when starting the bike and it runs , fuel pump runs constantly .
only getting now a strange readout from the empty tank meter , almost no gas in the tank now , no red blok for empty tank now , but al bloks blinking now up and down ?
stil dont get it with the orginal connector from the bike site ,,,, reading/getting 12volt and minus, connect to fueltank , nothing works .12volt and minus direct from battery and pump is working ?
timmy 1
Oct 28, 2017 10:20 AM
matt121
Oct 9, 2017 03:07 PM
lqdcat
Jun 2, 2009 10:02 PM
gaillarry
Sep 19, 2008 01:49 AM
brokenbonesjohn
Mar 15, 2008 10:23 PM
