2009 CBR600RR - No Power/Lights/Start at Key On, but will push start
Old May 2, 2020 | 07:27 PM
Fatal's Avatar
Default Solved: 2009 CBR600RR - No Power/Lights/Start at Key On, but will push start
Hello,
I have a 2009 CBR600RR that will not start when the key is switched on. Then the key is turned to the ON position, no lights on the dash, headlights/tail lights, etc do NOT turn on. However when the key is in the ON position, the bike will push start no problem, all lights will turn on, and stay running without issue after the push start. But once you switch the bike off, it will once again not display any lights and not start unless it is push started.
I have verified the battery is good, tried a new battery anyway, and a known good battery from a friend, and the behavior persisted among all batteries.
Old May 3, 2020 | 08:10 AM
Fatal's Avatar
Solved, it was a blown main fuse.
Old Jun 5, 2020 | 07:56 AM
PTeezy's Avatar
did or do you have a picture of the blown fuse? i'm keeping this in mind because i'm going to service my bike. thanks
Old Oct 21, 2020 | 01:01 PM
alexsol's Avatar
cool that you can still run the RR without main fuse... i had same issue and replaced with the 'spare' next to the main... i'll take a pic and send over...
rider0033
May 30, 2016 06:01 PM
titus sublett
F2 Tech
Mar 6, 2012 10:35 AM
batman4114
Apr 25, 2010 09:33 PM
ishboo22
Apr 16, 2009 10:12 PM
tonyB11
Oct 26, 2007 06:44 PM
