1000 rr damper
Old 09-05-2005, 05:34 PM
steve's Avatar
Default 1000 rr damper
Does anyone know if the 1000rr steering damper will fit on a 600rr.
Old 09-05-2005, 07:11 PM
Anubis's Avatar
Default RE: 1000 rr damper
I don`t know for sure but it should fit but you`d need to make the mounts for it to attach to, could get complicated.
Old 09-06-2005, 01:17 AM
josho66's Avatar
Is there not one specific for the 600RR right now??? Don't know, just asking.
Old 09-06-2005, 05:41 AM
get a scotts... its 10000000000000 tiems better than the 1000rr one...
thats eds (electronic steering dampner) DOESNT WORK WORTH A DAMN in my book, but others say it helps... helps is nothing compared to WORKING...
Get a scotts. and no the esd wont work, its electronic. so youd have MADDD wiring complications... most likely.
Old 09-06-2005, 07:34 AM
Anubis's Avatar
I`ve gotta disagree i recently had the rear tyre let go at 85+ and the steering damper worked spot on as it should controling the potentially violent slapper that was coming my way! I stayed on can`t say that it didn`t work there.
Old 09-07-2005, 08:53 AM
I shoulda specified...its under 35-45??(cant remember) it doesnt work.?.? when we rode red rock out here, it doesnt work at lower speeds... as well as higher speeds... so when your dippin n draggin at low speeds, no worky...
Scotts. fully adjustable, and works all the time..
I shoulda said that before. lol
Old 09-08-2005, 02:23 AM
possibility that it will fit...but it's also electronic...HESD= Honda Electrical Steerng Damper...so it's not only mounting it, but also wiring it in order for it to work properly.
buffddy16
03-06-2009 07:34 AM
Andres
08-13-2008 06:13 AM
K1W1T3K
06-21-2006 07:28 AM
mrc03rr
07-07-2005 04:12 AM
Quick Reply: 1000 rr damper
