07 CBR600RR headlight help!
Old Jun 3, 2023 | 12:44 PM
Real Jock's Avatar
Default 07 CBR600RR headlight help!
First time posting here, I can’t find an answer to my problem online.
I bought a wrecked 07 CBR600RR and have been rebuilding it and everything runs/works fine so far. Went to get it inspected (in Texas) and they failed it because the High/Low beams don’t switch.
My headlights are both on at the same time on low however when I flip the bright switch nothing happens. The “bright light” indicator lights up on the cluster but the lights do not get brighter or dimmer.
I am unsure where to start because the headlight housing is new, bulbs are new, and the switch is at least working to the cluster. I thought only one low beam is supposed to be on low and the other turns on when brights are activated. I’m open to any suggestions on how to fix it to pass inspection.
Old Jun 3, 2023 | 01:20 PM
dannoxyz's Avatar
Greetings & Salutations!!
Someone hacked your headlights!!
Both lights are single-filament, they DO NOT change.
Right side is low-beam and on full-time.
Left side is high-bean and OFF until you flip dimmer switch to High. Then high-beam light turns ON
Low-beam light stays same regardless of dimmer switch position
Old Jun 3, 2023 | 02:15 PM
Real Jock's Avatar
Oof! Well I suppose it could be a wiring issue? Maybe try to track the bright side to make sure it’s the only one plugged into the left side?
Old Jun 3, 2023 | 02:53 PM
dannoxyz's Avatar
Yes, get wiring diagram so you can trace wires and restore back to to factory OEM configuration.
1. low-beam is powered through start-button so that it turns off headlight when you push start-button
2. hi-beam is powered through hi-beam relay, which is activated by dimmer-switch.
They are on completely different circuits and don't share anything in common except for ground.
Old Jun 3, 2023 | 04:30 PM
Real Jock's Avatar
I’ll try that and update the progress. Preciate it!
Old Jun 3, 2023 | 04:41 PM
dannoxyz's Avatar
Here's wiring-diagram for '07-08
What I like to do is print it out full-size (on 11x17 paper if possible). Then trace circuits in question with coloured markers. That helps me understand how headlights circuit works. And helps me trace wiring on bike to ensure it matches diagram.
Good luck!
Old Jun 10, 2023 | 12:33 AM
Real Jock's Avatar
UPDATE
So turns out it wasn’t a wiring issue, it was a combination of a bad bright switch and a bad headlight relay! Both have been fixed! Thanks for the help!
Old Jun 10, 2023 | 03:42 AM
dannoxyz's Avatar
Awesome job!
KICKERMAN
Jul 13, 2022 12:29 AM
SleepySky
Nov 3, 2013 08:17 PM
cbr_rob
Apr 1, 2013 10:03 AM
oOoGILLoOo
Aug 12, 2010 08:37 PM
kylecbr600rr
Sep 16, 2009 02:08 PM
