06 600RR or 06 Triumph 675?
Old Sep 4, 2006 | 09:55 PM
brancart1's Avatar
Default 06 600RR or 06 Triumph 675?
I just sold my motorcycle and i want to move on to something better but i cant decide what i think is a better buy. I absoltuly LOVE honda and am having a hard time with the idea of going to a new company but the 675 is just a sexy motorcycle. I am just trying to an idea on what everyone thinks. I also realize that alot of ya'll are gonna choose the honda cause im posting this in the RR section but i really want everyone opinions.
Old Sep 4, 2006 | 10:49 PM
steve00ses's Avatar
Default RE: 06 600RR or 06 Triumph 675?
i want to see actual specs sheet on the 675. it looks nice, loks like the rr brother.
Old Sep 4, 2006 | 11:09 PM
christopher's Avatar
General information
Model: Triumph Daytona 675
Year: 2006
Category: Sport
Rating: 72.1 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 675.00 ccm (41.19 cubic inches)
Engine type: In-line three
Stroke: 4
Power: 125.00 HP (91.2 kW)) @ 12500 RPM
Torque: 72.00 Nm (7.3 kgf-m or 53.1 ft.lbs) @ 11750 RPM
Compression: 12.7:1
Bore x stroke: 74.0 x 52.3 mm (2.9 x 2.1 inches)
Fuel system: Injection. Multipoint sequential electronic fuel injection with forced air induction
Fuel control: DOHC
Ignition: Digital - inductive type - via electronic engine management system
Starter: Electric
Cooling system: Liquid
Gearbox: 6-speed
Transmission type
final drive: Chain
Clutch: Wet. multi-plate
Physical measures
Seat height: 825 mm (32.5 inches) If adjustable, lowest setting.
Overall height: 1,109 mm (43.7 inches)
Overall length: 2,010 mm (79.1 inches)
Overall width: 673 mm (26.5 inches)
Wheelbase: 1,392 mm (54.8 inches)
Chassis and dimensions
Frame type: Aluminum beam twin spar
Rake (fork angle): 23.5ยฐ
Front suspension: 41mm USD forks with adjustable preload. rebound and compression damping
Rear suspension: Monoshock with piggy back reservoir adjustable for preload. rebound and compression damping
Front tyre dimensions: 120/70-ZR17
Rear tyre dimensions: 180/55-ZR17
Front brakes: Double disc
Front brakes diameter: 308 mm (12.1 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Other specifications
Fuel capacity: 17.40 litres (4.60 gallons)
Color options: Scorched Yellow. Tornado Red. Graphite
Further information
Parts and accessories Check out parts and accessories from our partners.
Ask questions Join the 06 Triumph Daytona 675 discussion group
Insurance, loans, tests Search the web for dealers, loan and insurance costs, tests, customizing, etc.
Related bikes List related bikes for comparison of specs
Heres some specs on a 06 triumph daytona 675. Its an awesome looking bike!
Old Sep 4, 2006 | 11:56 PM
knightslugger's Avatar
Please define your version of BETTER, because my definition could be much different than that of yours.
also, i'd be great if you told us what you HAD. Hard to really give you solid advice if your list ride was a ScootyPuff Jr.
Old Sep 5, 2006 | 01:25 AM
rippn's Avatar
Trump, is a bit more focused than your 6 was... On the edge, carve'n. Less apt to make the daily med- high mileage, comfortably as Hondas are known for. They do fine against gsx-r 750's and stay up w/ many 1000's, in the right hands. Have you sat on one????? about as minimalist seat/ tank juncture, as ever seen. If you like sexy, you'll love the tripple howl. The determination of your specific focus, is yours. It would surely stick out in a crowd,w/ the prowess, to back it up. Clean and free, Ripp'n
Old Sep 5, 2006 | 04:19 AM
DThompson's Avatar
I think that 675 looks awesome, and with 125 HP. Its stands right up there with the RVT 1000R and weighs less.
Old Sep 5, 2006 | 07:43 AM
HighRevver's Avatar
He modified those stats for some reason...(which i would like to know....?) Here are the real stats from the triumph website
Engine Type Liquid-cooled, DOHC, in-line 3-cylinder
Capacity 675cc
Bore/Stroke 74.0 x 52.3mm
Compression Ratio 12.65:1
Fuel System Multipoint sequential electronic fuel injection with forced air induction
Ignition Digital - inductive type - via electronic engine management system
Transmission Primary Drive Gear
Final Drive O ring chain
Clutch Wet, multi-plate
Gearbox 6-speed, close ratio
Cycle Parts Frame Aluminum beam twin spar
Swingarm Braced, twin-sided, aluminum alloy with adjustable pivot position
Front Wheel Alloy 5-spoke, 17 x 3.5in
Rear Wheel Alloy 5-spoke, 17 x 5.5in
Front Tyre 120/70 ZR 17
Rear Tyre 180/55 ZR 17
Front Suspension 41mm USD forks with adjustable preload, rebound and compression damping
Rear Suspension Monoshock with piggy back reservoir adjustable for preload, rebound and compression damping
Front Brakes Twin 308mm floating discs, 4 piston radial calipers with radial master cylinder
Rear Brakes Single 220mm disc, single piston caliper
Dimensions Length 2010mm (79.1in)
Width (Handlebars) 673mm (26.5in)
Height 1109mm (43.7in)
Seat Height 825mm (32.5in)
Wheelbase 1392mm (54.8in)
Rake/Trail 23.5ยบ/86.8mm
Fuel Tank Capacity 17.4 liters (4.6 gal US)
Performance (Measured at crankshaft to DIN 70020) Maximum Power 125PS (123bhp) at 12,500 rpm
Maximum Torque 72Nm (53ft.lbf) at 11,750 rpm
Colours Scorched Yellow, Tornado Red, Graphite
Price $8,999 MSRP
putting 125hp and 123bhp is a HUGE Difference......The 123 not 125 is measured at the CRANK not the wheel and like i posted in the other thread on this damn bike the Yamaha R6 makes over 130BHP and ours makes 119BHP and the kawi prolly hits a higher BHP than this tri675 also.
So whats the big F***in' deal about this thing.???????????
Old Sep 5, 2006 | 08:05 AM
slipper's Avatar
theres no big deal but its a serious contender.
Old Sep 5, 2006 | 02:25 PM
DThompson's Avatar
I havent seen any factory specs that were measuring HP at the wheel. So whats the big deal about it being measured at the crank??? Thats where all of the HP measurement come from with new bikes.
Old Sep 5, 2006 | 02:43 PM
discohouse's Avatar
i read 103 at the crank for the 675 in Cycle World. The bike look nice, I just keep remembering the stories that one of my customer's tells me about leaking- (not the 675 but whatever he has). The bike is new, so I will be intersted in seeing the repair history.
