05 plastics on a 03
Old Dec 20, 2005 | 04:42 PM
dlbinford's Avatar
Default 05 plastics on a 03
Will 05' fairings off a CBR 600RR fit on a 03' CBR 600RR?
Old Dec 20, 2005 | 06:20 PM
doncollins's Avatar
Retired Administrator
Default RE: 05 plastics on a 03
deja vu.....
to quote MgA_ODEN about 03-04 plastic fitting an 05...
Yes , All you need to get the upper to fit is the Ram air tube and box that sits in the upper.
Other then the upper and windscreen, you will need the left and the right air ducts, spoiler, and the cover, here are the part numbers...
Right air duct- 64330-MEE-D00
Left air duct- 64380-MEE-A00
Spoiler- 64321-MEE-D00
Cover- 64230-MEE-D00
The spoiler is the bottom piece, and the cover is the piece that the air ducts mount with, you can see the parts with the microfiche on ronayers.com if you want to check that out, you will also need some of the plastic clips too, part# 90683-GR1-003. I think you need 4, these are the clips that go on the spoiler to hold it in place
I know you are going the other way, but you can see that you have to buy a lot of pieces to make it work.
Old Dec 21, 2005 | 11:49 AM
Rev's Avatar
Rev
wow don..good ****..this is good info..thanks..
Old Dec 21, 2005 | 01:10 PM
doncollins's Avatar
all of that came from another member, MgA_ODEN. PM him if you need more to work with. The parts are to fit the 03/04 on the 05.... He might know, or can look up what you need to put the 05 on the 03/04.
cumminsboy3
Jun 11, 2009 09:19 PM
chiefF3
May 1, 2009 11:04 AM
12 O Clock
Mar 8, 2007 12:58 PM
DevenJames2005
Jan 8, 2007 09:10 PM
