04 600RR Charging System problems
Old Dec 26, 2007 | 05:32 PM
Missoutkast's Avatar
Default 04 600RR Charging System problems
Does anyone know if there are common problems with the charging system on the 04 model? I have replaced the battery before and it does not seem to help. A friend of mine also has the same problem with her bike as well.
Thanks.
Old Dec 26, 2007 | 05:48 PM
sixhundredrr's Avatar
Default RE: 04 600RR Charging System problems
Is your system dead or does it keep draining the battery? I believe 03/04's have regulator rectifier issues. Look up the service manual in the general tech section of the site and it will point you in the right direction for the charging system.
Old Dec 26, 2007 | 06:35 PM
Jason748's Avatar
Yep, on the 03/04's they have a know issues with the voltage regulator / regulator mount when used mostly at low RPM around town use - Its a heat issue that kills them. The fix is to replace it with the 05/06 voltage regulator& mount assembly.
ddavis17
Jun 4, 2012 05:39 PM
guyomatic
Oct 20, 2011 10:02 PM
zrad
Feb 20, 2008 01:59 AM
lococbrf2
Oct 14, 2007 11:38 PM
bellamach2
Jul 16, 2007 10:28 AM
