03 rear shock
Old Apr 22, 2008 | 11:38 PM
endleesss's Avatar
Default 03 rear shock
Is there a way to adjust the rear shock to make it higher or lower?
What do the numbers 1 through 7 mean on the bottom of the shocks? Soft/High? If so is 1 soft or high?
Thanks
Old Apr 22, 2008 | 11:52 PM
gotobatter's Avatar
Default RE: 03 rear shock
not quite sure man. did you check the owners manual?
Old Apr 22, 2008 | 11:55 PM
endleesss's Avatar
I checked the service manual, it doesn't say anything. I have a 2003 CBR 600RR btw.
Old May 8, 2008 | 03:39 PM
endleesss's Avatar
anyone else know?
Old May 8, 2008 | 08:33 PM
Jason748's Avatar
No you cannot adjust the stock rear shock height.
The number are the spring-preload setting (for setting your sag), with 1 being the least amount and 7 the most. Changing this does make the spring softer or harder it just changes where the internal valving sits inside the shock.
robertjhunt
Jun 23, 2010 06:01 PM
Noam
May 22, 2008 12:15 PM
